Spook
- Granite
I am just getting ready (plucking up the courage) to swap the RX in my granite so I can swap the Spectrum for a Radiolink... I have watched a few videos and understand that channel 1 is steering and channel 2 is throttle.
however, do the plugs always go in the same way round ? Is there a way to check which wire does what ? the instructions show which pin is ground, vcc and signal (not sure what each actually does, although I guess that’s not important) Are these wires standard colours for example so I know the correct orientation ?
many thanks.
many thanks.
