Thanks for the reply. It was pretty tight. I loosened it a little but it still cut off after a couple of minutes. I'm going to try loosening it a bit more. When it cuts out it flashes red slowly but it does not feel hot to touch?@sparky_18 How tight is the gear mesh, between the spur and pinion? If it's to tight, try this.
http://arrmaforum.com/threads/noob-spur-pinion-gear-meshing-tip.140/
It is a Granite Mega.Which Granite?
I'm running my fury on upgraded spur and pinion and have got that thing cooking but it's never cut out. Sounds like something is a miss.
Based on 6 cell nimh... 7 cell nimh is 8.4volt iirc.... Nimh full voltage is 7.4 volts
If its doing it on both batteries then it might be something else. None the less id still try and see if you have the same issue i had. Check out this thread.
http://arrmaforum.com/threads/esc-shutting-off.487/#post-4905
