MacSpacey
Hello kind peeps, I am getting ready to go to my local hobby store and I am going to start a new Conversion based on the lwb composite chassis that is shared with the Big Rock 3s the Senton 3s the Typhon 3s and the Kraton 4s
I have been very busy with the parts needed to get the job done
RIGHT
First thing is to choose with which base model you are using for your start point.
I think I have worked out the most budget friendly and also the easiest possible start with the base model being the Arrma Big Rock Crew Cab which is going to be converted into a Arrma Senton 3s
First the wheels are the most expensive part of the whole change.
So without further ado
You go and buy yourself an brand new
Big Rock CC
AND THEN GET THE FOLLOWING PARTS
AR320405 SC BUMPER SET
AR320406 NERF BARS
AR320407 BODY MOUNT SET
AR320419 LOWER SKIDPLATES
AR320421 SIDE GUARD
This is all installed on the
AR320397 COMPOSITE CHASSIS LWB
then put on the wheels
AR402204 DBOOTS FORTRESS SC TIRES
And then the body should fit without any problems
AR402204 SENTON BODY GREEN BLACK
The next time I will have worked out the next step in the Conversion Cycle
I hope you guys are enjoying the information that I've been working on for a couple of hours now. So Greetings from the Netherlands
MacSpacey OUT
PEACE!!!!
Eat?Sleep?Bash?〽?Repeat?
RIGHT
Big Rock CC
AR320406 NERF BARS
AR320421 SIDE GUARD
MacSpacey OUT
PEACE!!!!
