Senton Convert granite to senton?
TheJMatt
  2. 4x4-Mega
Anyone know what it would take to convert the granite over to be a senton sct? Is it just tires and body? From what I can tell, most all the other parts are the same right?
Thanks,
Add Chassis and probably driveshaft. I am pretty sure the Granite is SWB, and the Senton is LWB. Might check the Arrma site to see if the suspension arms are the same part # - I wonder if the Senton is wider?
Yeah the senton is a bit longer with different frames most everything else is the same. Looks to be a hassle to swap considering you get a non upgradable car. Oh well. .
Its actually quite easy chaps, I turned me granite into a senton as my son wanted both of our rc's to look the same.
You just need to purchase the front and rear bumper assembly, the body mounts (then just fit them backto front when fitting) this overcomes the shorter chassis. Then a little trimming of the body around the wheels. I haven't got the wheel arches 100% yet but still happy with the outcome.
So the senton bumper will bolt up to the granite chassis with no modifications? Or did you have to alter it
