Typhon Convert Typhon 6S V5 to TLR tuned
WRCG
California
  1. Kraton EXB
  2. Typhon 3s
  3. Vorteks
  4. Voltage
Anyone know what is needed to convert a 6s v5 typhon to its tuned TLR version? I'm mainly referring to shock towers and wings.
mmm, it's more complicated than that. the shock tower are higher, meaning you need the longer shocks that comes with the TLR, also the front shock tower requires the hinge pin insterts and hinge pin, instead of the hinge "screw" that is used on the v5. and to have the correct lengh for you pin you'de probably need the rear suspension holder for the front upper hinge pin
You are completely right. Thanks for pointing out my mistake!
Shouldn't have sleepily looked at the exploded view 😅
