Kraton Cooling fan.
Ole Fart51
Louisiana
  2. Talion
I'm wanting a Hobbywing heat sink and fan. Does anyone know what part number that will work on my Momba Monster 2200kv set up?
tezauk
South Wales UK
The one I got for the stock v2 motor was this "Hobbywing Ezrun C4 5V" I'm guessing the monster can is around the same size ?
Vanning
If it's 40-42mm it will fit. You may have to bend it in a little. Remove the fan before you tweak it....adjust the fins..then screw the fan back on. I posted some info on one of those fans on here under
https://arrmaforum.com/threads/motor-swap-in-kraton.1398/page-3 That's on a 2200KV Castle motor. If that's the one you are talking about.
Check out my mods to it....unreal cooling action. Works awesome.
