Typhon Cooling fans for typhon 6s
jarbizo
Sydney, Australia
  1. BigRock
  2. Kraton EXB
  3. Senton 3s
Hey Guys, what cooling fans do you recommend for the typhon 6s? will the hobby wing fan fit? About to get a typhon soon but just checking on fans that fit. I'm using the same on the EXB although its wide and the heatsink needs to be squeezed in a bit. Thanks!
I use the yeah racing twin fans and heatsink. But I upgraded the plastic fans for the yeah racing alum fans
yeah racing twin setup is the lowest profile. I'd recommend staying with a 40mm can motor on the typhon when you get advanced rc syndrome just so you can clear a decent fan/heat sink combo. I run a hobbystar 4092 motor with mine. You could probably fit the hobbywing heat sink and a 50x20mm fan, but they like 12v and you'd have to pack a 3s lipo under the body somewhere or run off the 6s balance plug with a voltage reducer.
Check NTF Racing on Facebook 👊
40x28’s won’t fit under a typhon body. You could turn it sideways and cut part of the body out or top I guess.
