Copper heatsink for BLX 2050kv motor.
Thread starter #1
leo248
Likes
UK
Talion
I decided to try and reduce the temperatures of my Talion's motor since even on 4S it was getting quite hot.
I wrapped some copper foil around the motor 2-3 times to see if it reduced temps.
I ran the car on grass today for 2 4S packs worth and the copper did work! the temps were around 65-70 celsius (149 - 158 fahrenheit) before and with the copper it was around 48-50 celsius (118 - 122 fahrenheit).
Since only the silver fins on the motor are covered it did only reduce the temperature in that area so I intend to cover the rest of the motor can with the copper to make the temperature more even across the motor can. If anyone is interested I used 30mm wide 0.03mm thick copper foil.
ThatDrewGuy
ArrmaForum Fan
Likes
155
Chicago Area
Granite, Kraton, Talion, Typhon
So that seems to work nicely! I'm curious how that would do on 6S in a warm climate. Been running at almost 190 F on the Talion with 6S because it's 95F here. So I started using the Yeah racing twin fan setup, and that dropped me 30 degrees in this heat so far. Would post a picture if I was home.... Here's the link to the fan
https://www.ebay.com/itm/Yeah-Racin...256619?hash=item1c64ebc26b:g:AAcAAOSw9IpX1R92
How much did you spend on the Copper?
Thread starter #3
leo248
Likes
UK
Talion
I
It was only £3.80
Thread starter #5
leo248
Likes
UK
Talion
ThatDrewGuy
ArrmaForum Fan
Likes
155
Chicago Area
I’m not sure how it works there, but I see stuff from all over the world on eBay. That’s where I got these. Ordered it in blue for my Typhon as well. Try eBay and if you can get them, I do recommend. 30 degrees was a huge difference.
Similar threads
