- BigRock
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Mojave
- Mojave EXB
- Nero
- Notorious
- Outcast 8s
- Outcast 6s
- Senton 6s
- Talion
So Corally tried to tempt the beast that is Arrma & crapped out a turd. It's fast as all hell. 40t/13t diffs & 46t/13t stock gearing is an easy 60 OoB if it doesn't burn alive first That type of gearing can torture any system, even the max8 combo it comes with - a beautiful system, one of the best I've seen in a RTR. My main gripe with this thing is that it has the WEAKEST metal chassis I've ever seen, period. Seriously, I wish I was joking. The chassis will bow as soon as you put a battery in it Forget running it stock, you'll just end up with a hot pretzel So how do you fix something like this. Anything less than divine intervention will end in tears . . .
I'm not going to say this was a PITA to fix, it just took a lot out of me & I was getting tired of working on it half-way though when I started on the T2T brace. I obviously got the bumper, wing mount/wheelie bar, fans, & body out the way first so I could figure out the bracing w/o having that lag work on the back burner.
