Bollucks
- Notorious
Hi everyone,
Had a good day of bashing yesterday and broke/lost a few things but no big deal. I was taking apart the rear end to try and get the two bolts that hold the wing on (that sheared off) and I open up the diff case to notice a decent amount of grit and dirt in there is that normal and if so how often are you going in there to clean out and replace the grease. Also what grease are you using I have some people recommend mobile 1 axle grease.
Second question is I noticed in the rear the cups that come off of the diff that the dog bones go into look to be deforming. Is that normal and is it possible to replace those or do you just have to replace the diff?
And finally the front right lower pillow ball yesterday kept loosening up on me. Initially resulting in the front dog bone falling out and when I got home noticed I lost some of those upper shims on the upper a arm. Is there something I can use to lock the screw in there like loctite or something? Also can you buy just those shims or do you have to buy a new set of upper arms.
thanks a ton
thanks a ton
