Many thanks for your quick response, as I said I’m new to the RC world and I like to get my head around things and understand how they work, please don’t take this the wrong way but my car was fine beforehand so isn’t your answer finding a solution to the problem rather than fixing what went wrong (hope you get what I mean)Go to programming and switch the motor rotation to opposite of what it is set at and then switch the channel 2 throttle reverse on the remote.
His advice is how you fix your issue. Different radios and ESCs have various orientations for forward and reverse. This is common. Right now your setup is backwards for the combo you have.Many thanks for your quick response, as I said I’m new to the RC world and I like to get my head around things and understand how they work, please don’t take this the wrong way but my car was fine beforehand so isn’t your answer finding a solution to the problem rather than fixing what went wrong (hope you get what I mean)
Right that explains it, many thanks to you both.His advice is how you fix your issue. Different radios and ESCs have various orientations for forward and reverse. This is common. Right now your setup is backwards for the combo you have.
