ParkRacing
- Thread starter
- #21
three of these babies on the way!!!
Be sure to enter the SMC Racing LiPo giveaway, you can never have to many batteries.three of these babies on the way!!!View attachment 3602
Good call, I will unplug the sensor wire first and try that. I am using the good old finger to motor method and am getting almost burned. I stopped using my temp sensor years ago when I found people at my local track getting very different results using theirs on just my motor? They don't seem to be accurate at all.What did you use to read the temp and what was the temp ?What tires, what terrain ?
My 5s is the stock motor, 2050KV I think, 14 tooth and Badlands 3.8 tires. Temp tops around 140. May see 160 once in a while. Always off-road in sandy short grass. I never get close to 180. Badlands may be like having a 12 tooth pinion If I'm running a 14 tooth. due to their smaller diameter. When compared to stock tires.
Try the 12 tooth first.
Make sure your gear mesh is loose. Turn down the punch a little, mess with motor timing, make sure you got good connectors and solder.
sounds like you have a racing motor and ESC.... but that should not matter. Mess with the ESC settings. A racing truggy could be lighter than a Kraton. Maybe look at the timing.. I think you can run in sensorless mode... try that. . idk. Keep us posted.
You should be able to run decent temps on 5S with that low KV motor. Maybe it wants more gear ? Bottom line.... It takes some trial and error. It could just be that sensored timing ??? That's something most bash vehicles don't have.
Idk, maybe I have a sensitive fingers. I just don't want to over heat it!
Yeah I use the 2 second rule and I can't do That even, so too hot. Yeah I cannot believe how heavy this truck is! Must Mugen mbx6 has a buttery smooth drive train and the kraton is a little crunchy especially after swimming the diffs, maybe too much resistance in the drivetrain...LOL...I find my heat temp gun very accurate.. You should be able to touch the motor about 10 seconds and not curse.. If you let out an Oh F*#@K ...it's too hot !!!! You know that rule of thumb already I'm sure. For some reason...you are drawing too much current. Turn the timing down low maybe...if you didn't already have it down. Add some to the Punch to lessen it. I think the Kraton is a heavy slob compared to race buggies and truggies. Also....did you ever notice how smooth the drive train spins on something like a Team Associated 1/8th buggy....it's close to no resistance. Kraton...not so much.
However...I'm running cool on 5S, no reason you can't get it working well also. Keep us posted.
My MugenYeah I use the 2 second rule and I can't do That even, so too hot. Yeah I cannot believe how heavy this truck is! Must Mugen mbx6 has a buttery smooth drive train and the kraton is a little crunchy especially after swimming the diffs, maybe too much resistance in the drivetrain...
Wow I need to proof read...Yeah I use the 2 second rule and I can't do That even, so too hot. Yeah I cannot believe how heavy this truck is! Must Mugen mbx6 has a buttery smooth drive train and the kraton is a little crunchy especially after swimming the diffs, maybe too much resistance in the drivetrain...
My Mugen
I am running deans, could that be an issue?LOL...I find my heat temp gun very accurate.. You should be able to touch the motor about 10 seconds and not curse.. If you let out an Oh F*#@K ...it's too hot !!!! You know that rule of thumb already I'm sure. For some reason...you are drawing too much current. Turn the timing down low maybe...if you didn't already have it down. Add some to the Punch to lessen it. I think the Kraton is a heavy slob compared to race buggies and truggies. Also....did you ever notice how smooth the drive train spins on something like a Team Associated 1/8th buggy....it's close to no resistance. Kraton...not so much.
Nah they're fine. I dud some research!I am running deans, could that be an issue?
I too use EC5 and prefer them much more.I switched to ec5 connectors and love them. Rated very high for amperage, very secure connection, trusted and endorsed by many with very expensive high powered planes/helicopters who depend on them to stay airborne. May also consider bad or failing bearing(s) somewhere adding rolling resistance/heat, akin to doing long climbs with RC.
Glad to hear you like them too. They are a tad pricey, but then you know your connector isn't a source of failure or unnecessary resistance. XT connectors are nice also, but ec5 is rated a bit higher and already made the switch with my other packs and rigs. I also prefer single connection/single hardcase brick when possible. Here's new EC5 on new Outcast, awaiting maiden voyage today!I too use EC5 and prefer them much more.
I think I will try ec5, how do I know if they are real or a knock off? I Have a fast eddy bearing kit coming today also, I have some really sad stock bearings right now!
I've bought all mine from LHS, maybe find cheaper online in packs, do like visiting/supporting store. They sell different combinations ie device/battery, EC5 is stamped on connector.I think I will try ec5, how do I know if they are real or a knock off? I Have a fast eddy bearing kit coming today also, I have some really sad stock bearings right now!
