Senton Custom home made parts lol 😂
travykat
Just looking at the stuff i have in my tool box thinking of making a center brace for my senton but will it work lol anybody made there own DIY parts for there rc
Easton acc arrow shafts make great center braces!
All the time , mostly carbon fiber. Raw sheets with epoxy to buying carbon tubes (center brace infraction 309mm) and carbon sheets. Sheets side skirts front splitter and side skirts. And some 3d printed parts when I had a printer. Wife couldn't handle the smell. And 40mm fans set of 2 motor 1 ESC for 12.00 ish. But for road cars.
I've made a center brace out of the under barrel bar thingy from a bb gun. Then a brace that goes on the chassis that probably did zero. I took both off.
Wow okay cool i was just thinking i was the only one lol over here like macgyver yea i think the real bracket & my own tube would look legit like Boggs im using a peice of a fishing rod & a 40cal shell to hide the fray from cutting the rod i think fishing rods are carbon fiber
All the time! My favorite is my home made pivot balls from 4mm clear tubing. Stock pivot balls don't last and when knew are super fiddly to fit. These fit snug but easy to lign up and they last.
Carbon fiber 10/2 tube center brace
ESC mount ACER Racing 2mm CF plate
Battery mount mode to Hot Racing battery mount. ACER Racing 2mm CF plate
Oh yea that looks clean i got to get my hands on some CF tubing it would look cool over the cvd shaft or a tierod
Stock plastic balls. A few small strips of TEF. tape in the End and pop the ball back in. It will be snug at first. Snip off any excess. Any visibly remaining T tape is fine. T tape is slippery. It will loosen. It works. Do every single ball end. Trial and error and you will know how many small strips of T tape will get it snug.
Will hold you for a while. Wears much slower. I do this mostly with my On roads stuff. Off road slop I can deal with.
Ooooh thats fresh ididnt evan think of the CF wrap
Get the 3M ones. The rest are a waste of money. I liked the Di Noc one better as it had a stronger hold.
5ft x 1ft (5 Sq/ft) 3Mâ„¢ Scotchprintâ„¢ Car Wrap Film 1080 CF12 Carbon Fiber Black https://www.amazon.ca/dp/B017BZC3VK/ref=cm_sw_r_apan_glt_i_F7Z19YZCYT2GH0679F8S3M Scotchprint Series Di-Noc Carbon Black 4ft x 2ft Vinyl Car Wrap Film Sheet Roll https://www.amazon.ca/dp/B01II9ZLWG/ref=cm_sw_r_apan_glt_i_FFG85AKDRVR4V4RF5FHE
4mm tubing cut to length. Slice off a small section or it won't fit. The photos of them in the rodend are at least 25 packs old and still have very little movement.
And 56 seconds into this on my Big Rock
