- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
Recently I have been running my Hobao VTE 2 on 2s speed runs.
The runs often are over 400 amps and it can be hard on the batteries. After looking around I noticed that some of the top of the line LiPo brands do not have offerings of the commonly used 6000 mAh cells in a 2s configuration.
Long story short I went with SMC and fried a cell after 3 runs. Not saying SMC is bad as many have good experiences.
I went to order another but it was sold out.
I then started looking for alternative solutions and decided I would finally make my own custom lipo.
I had laying around 2 Revolectrics 4s packs that I have never used because they were 4800mAh. The pack is 4 cells in series.
Cut the pack in half and you have 2x 2s packs.
Before I get much further I wanted to point out a few things. This is extremely dangerous and shouldn't be done anywhere inside your home.
I am doing this in my garage with the door open where I can toss the pack out into the driveway away from the house in a moments notice.
First step was to open it up very carefully. If a cell gets punctured and allows oxygen in its basically over and should be disposed of properly.
I began by separating the series connection in the middle making this 4s pack into 2x 2s packs. (I had a second one so now i have 4x 2s packs)
I removed the balance plug as I would be soldering on a new one and just taped those ends off so that no shorting would occur.
I followed a guide from Peter Dirks where he mentioned getting the packs cold before applying the soldering iron on them to help avoiding damage. He also mentioned you need to apply the heat for a short duration of time. He recommends a large chisel type soldering iron of 80 or more watts. I ordered a Weller 100 watt off amazon and this thing rocks!!!
Old 30/130watt Weller vs New 100 watt Weller
At this point I had 4x 2s packs ready to begin the process. I used tape to isolate any connections from an accidental short.
Next I used the freezer to cool down the packs but not very long like 10 mins. If they get too cold then you deal with condensation issues....
I started by removing the main power wire leads with the soldering iron.
Next came soldering on my new heavy ga. wire (8ga castle wire and you could go with 6 ga.) I had already set this wire up on QS8 connectors.
(notice how close on the other side of the tape that was already there from Revolectrics how close the opposing cell tab is.
At this point I have 2 separate 2 cell packs that I need to make parallel. So as they saying goes..... Red to red and black to black...
Be cautious and tape over any tabs/exposed metal that could be touched accidentally.
2 Wood working clams worked awesome to hold the pack straight up, very stable, and could work on it.
Final step was to install a new balance plug for 2s. (available on amazon)
Then tape everything up and wrap it up!
Found PVC shrink wrap the right size also on Amazon
Now I have a high output 9,600 mAh 2 cell pack to use with 8 gauge wiring.
I just hope it does not blow up and catch fire!!!!
Already tested it on the charger and cells are still balanced and look good!
