- Fireteam
- Typhon 6s
Got this thing close to finished. Just a few things left to go now. Need to solder new connectors to the motor wires and esc plug then run all the wiring to the receiver and get it secured. After that I want to see what other options for mounting a wing I have, I just have a couple of Arrma body mounts that happen to fit and will work but I'd rather have something a little more robust. Also need to figure out exactly how I'll mount the body but that should be pretty easy. I'm hoping to finish up this weekend but I'm having problems using my hands due to nerve issues in my neck. Looking forward to seeing what this little beast will look like finished!
I've never seen a Bandit in person so I just bought the plastic chassis a few months back and started putting parts on it a little at a time. The FLM extended chassis was out of stock for a while but finally got that about 3-4 weeks ago and got the electronics after that.
Here's the build...
Electronics:
Hobbywing Max10 G2 140A esc
Hobbystar 4068 2400kv motor
30kg servo
X6GF receiver
Front:
RPM Slash front bumper (RPM80592)
RPM bulkhead (RPM73752)
RPM Slash wide suspension arms (RPM70552)
ST Racing hardened suspension pins (ST3640BK)
Arrma 4x60mm turnbuckle (ARA330601)
Team Losi 4.5x45mm turnbuckle TLR244054
RPM Rod Ends (RPM80512)
ST Racing caster blocks (ST3632S)
ST Racing oversize front knuckles (ST3636S)
Traxxas front axles (TRA3637)
Tekno RC 12mm 7075 aluminum hex (TKR1654X)
Hot Racing 17mm hex adapter +10mm offset (HRAWH17HT01)
ST Racing shock caps (ST3637S) & bodies (front ST3765XS & rear ST3766XS)
Traxxas GTR shock shafts (front TRA2765T & rear TRA2656T)
Hot Racing Progressive Springs (front HRASLF48FS261 & rear HRASLF63FS261)
Chassis:
Atomik RC front shock tower (4129GM)
Fast Lane Machine rear shock tower (FLM22500)
Fast Lane Machine extended Bandit chassis kit w/upper chassis (FLM22805)
Traxxas Receiver box (TRA3628)
Rear:
Fast Lane Machine aluminum transmission & 7075 sealed diff (FLM20200N)
Tekno RC drive cups/driveshafts/hub carriers/axles/bearings (TKR1951X)
ST Racing 4x40mm turnbuckles (ST3737S)
Tires:
Rear- Badlands MX28 belted 2.8mt
Front- Badlands MX28 2.2/3.0sct
Here's the build...
Electronics:
30kg servo
X6GF receiver
Front:
Chassis:
Rear:
Tires:
