Cv joint keeps disconnecting
Virginia mud
Cv joint on right rear keeps disconnecting even after replacement. What is happening?
Edough13
Bashing, Speed running and family!!
Hospitality Award
Northern California, USA
  1. BigRock 4x4
  2. Granite
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Typhon 6s
  8. Vorteks
I'd guess your slipper is too tight or could possibly be a bad bearing seized in the hub not allowing it to spin freely.
SrC
RC is a lifestyle choice
Hospitality Award
Queens, NYC
  1. Fireteam
  2. Infraction
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Typhon TLR
After this happens once then twice and with subsequent re-attatching, it will just be more problematic. It is just worn out. Undue loading causes this like stated in the above post by @Edough13. Check your slipper setting. It is the only buffer to excessive loads or binding.
Greengaunja
Ise da by' dat burns da Senton........
Durham Region, Ontario Canuckistan
  2. Senton 3s
I was having the same problem to and the cause was a maxed punch level. You can turn down punch or do what I did: buy Hot Racing CVDs and watch pins break until the u joint does. Then try GPMs to notice a horrible imbalance and vibration "shudder". As a last resort, try Arrmas HD CVD and be surprised they actually hold up better than the others.
#AR310870 (ARAC3974)
AR310870 or ARAC3974
Exc3l
Canada, Mississauga
  2. Outcast 6s
  3. Typhon 6s
Get Arrma CVD's like @Greengaunja mentioned . I have turned down my slipper but I keep breaking em. For now loosen your slipper and put the shaft together. Once you put it back together, take a Hair dryer and warm up the joint. Then take pliers and bend the plastic around the pin. That should make it stronger and get you running.
Greengaunja
  2. Senton 3s
Were you able to find them? My lhs ordered them for me. When I first went this route, they had only 1 ARRMA set and 1 Hot Racing set. The HR require changing outputs(supplied with shafts). When HR went FUBAR, I tried a set of GPMs only to learn why they have several in stock. No one buys them.
ARRMA, still going strong
GPM, bulky and imbalanced
I actually thought GPM would be idea as admittedly they seem solid but there are huge noticeable differences in handling. None of it good
Here is why HR should be avoided
If you look at the top part of the shafts, you can see the thin wire like metal wrapped around shaft. Both had pins that broke first run. The metal was a paperclip used to do temporary repairs to salvage my bash session. And they lasted 6 more runs until u joint broke.
My 6S is FULL of HR parts. I like HR. But when a paper clip performs better than their "hardened pins", something is off. Their response was I abused them, which im going to admit to since I run with punch level maxed. Yet it doesn't change the fact that common paper clips survived my punch level.
Funniest part of that conversation I had with them is, punch has nothing to do with this. The pin merely holds two splined parts together(it slides at the bottom). The pins broke from jumps.
