Typhon CVD axle upgrade
Typhon3sboogie
Can anyone who has done this upgrade on a typhon 3s give me help? I installed the axles but where the wheel mounts up it's different. The way the wheel mounts it looks like it needs some kind of adapter? The ends on the stock axle have the screw that pushes on the pin, but the upgraded CVD slider set (AR310870) just has a threaded rod... any help is much appreciated.
Which CVD's are you referring to?
The Typhon 3s uses a 17mm hex??? The part number you gave is for a BR or Granite.
If you want to run the Typhon 3s wheels still you will need to buy the Granite 4x4 hexes then buy some 14mm to 17mm hex adapters.
These https://www.arrma-rc.com/part/AR310870
Here is the difference. Too one is stock. Bottom is CVD slider.
Oh sheet. Do you know the part number to the correct axle?
