ajdragon
- Raider
Hi
To anyone who is interested there is a way to get CVD's for the 2 wheel drive 1/10 scale Arrma's. It requires the installation of A.E. SC10 parts. The rear axle hubs for the SC10 pretty much has the same dimensions as the rear axle hub for the Arrma 1/10 scale vehicles. And they both have 3/16" or 5mm Axle's that are the same length 44mm.
All you need are four parts
Associated MIP CVD Axle RC10B4 ASC9598
Associated CVD Rebuild Kit T2/T3 ASC7381
MIP Blue Thread Gel/Grease Cup 5201
And the forth part "the bones" depends on what length your axles are.
My raider XL uses 80mm dog bones, but the CVD bones need to be longer because the back part of the CVD axles are shorter then the stock axels by almost 3mm. I figure I will need ether a 85mm to 89mm axle. I figure between 3mm and 5mm is what you will have to add in order to get the right length of CVD Bone.
Also RPM makes a rear axle hub for the SC10 that looks a lot like the Arrma 1/10 stock rear axle hubs.
part #70172
part #70172
