Easy way is to buy a set from JRC. You just need the same as the front. You will have spare centers this way too.Looking for part #s to upgrade all dogbones/ to CVD joints for Arrma Typhon 6s BLX V.4
Much appreciated, if anyone knows them....
Yes sir that’s what I have done on al three of my 6S trucks. Obviously you need the Kraton set for a Kraton and Typhon for a Typhon, but yes just get a front set for the rear. Make sure to check your arm travel without the shocks mounted to ensure the cups don’t bind. If you run extreme camber in the rear, it could bind. Set your droop too.Hey @jondilly1974 can the same thing be done with the Kraton 6s?
Should be good. Just verify before putting power thru them ??Im running the stock camber and droop with RPM arms.
