Did he seriously reuse a Dremel slotted screw? Dude.. WTF..
Both . it’s always worth the effort to disassemble a used car completelyYou talking about the Phillips heads or the grub screws being so tight the sway's don't even move? Or the front hinge pin retainer plate being upside down?
Euhm no…i did, couldn’t get it out because it was won out. Am i about to learn something newDid he seriously reuse a Dremel slotted screw? Dude.. WTF..
ah okay, yeah I’ve seen that too . Fortunately he didn’t but he sure did use some strong loctitePerfect! That's how it's done! I thought he might have reused it, wouldn't be the first time I seen that either
After some thinking I came to the conclusion I’ll be riding this car more of than on the track. If I would try and find a setup that’s good for bashing but still fun on track. What diff fluids would be suitable? Something like F7-C10-R5?Will you be racing it? If you're going to bash that buggy, you'll need a totally different set up.
Here's what mine was set up at for racing. I pretty much do the same with a few minor tweaks with 1/8th buggies. If you're going to eyeball these settings, it's going to be hard. Need a set up station to dial in any race buggy properly.
Ride: 27-28mm (bones just under flush center with the ground)
Shocks: stock 3-hole piston 100% rebound 25WT front, 20Wt rear.
Diffs: F-7k, C-5k, R-3k.
F camber -1.5
R camber -2
F toe -1.5
R toe stock default I believe is -2
Front castor, stock default of I believe +2
For bashing, I would go heavier in the CD, keep the front and rear diff’s around 10k (less in the rear) and raise your right height a few MM. I could be wrong I could be right, never really bashed a buggy. Even then you still could be unloading on the front with traction.After some thinking I came to the conclusion I’ll be riding this car more of than on the track. If I would try and find a setup that’s good for bashing but still fun on track. What diff fluids would be suitable? Something like F7-C10-R5?
That is awesome. I've never bent the center shafts in mine but it is good to know that a thicker option is available. Does the front fit then? I currently have the D8 front center cvd shaft in mine.Installed the rear section today and upgraded the original 3mm rear center driveshaft for a 4mm one. The Corally Radix’ rear driveshaft was a de direct fit.
I think you can an program it without the program card.I wanted to know what the setting is the ESC where. I didn’t really wanted to buy a Castle Link but annoyingly Castle doesn’t let you program the esc manually like Hobbywing does (as far as I know).
Played with the thought just replacing the ESC for a Max 8 but since I never owned a Castle esc I was curious if I would notice the difference and bit the bullet on the 35 euro for the Castle Link.
In the end I was happy I checked the settings. The LVC was set on 3v (changed it to 3.5 which was the max setting) and the bec was set at 5v ( in line with the standards of 2010 ), upped this to 7v.
