Rickard
Update 1 - Am I looking for a problem that aren't there?
So, I took things apart, very good training and get to know the car better.
I can feel the "problem"/noise is coming from these parts
AR310873 - HD INPUT GEAR 13T
AR310872 - DIFF CASE SET 37T MAIN GEAR
I don't see that there are any damaged parts, everything is tight and that starts me wondering if I'm looking for a problem that aren't there? But I feel the noise is abnormal when running the car.
I can see that there are grease that has left the gears and is in the housing rather than on the gears, it seems that the sound is coming from the gears and that might be normal? or could it be that my son drove it to hard the first time throwing all of the grease off of the gears?
I have tested the front differential, just rotating it with the driveshaft and the feeling is that the front has less resistance and noise.
The slipper clutch and pinion gear looks great, I mean the car has only been driven for approx 40 mins. I will probably change the slipper hub and driveshaft that is damaged.
Videos and pics here: https://www.dropbox.com/sh/x59urmynp8zab49/AACxQbxd2ueKiOCMWs6hfSL7a?dl=0
These are the new videos and pics.
/Rickard
Hi, I'm a noob with rc cars, bought myself a Granite 4x4 3s. First test ended with failure, a small stone came into the chassis and jammed the driveshaft. It locked the frontweels and i was finished driving for the day. It jammed between the cooling flanges and driveshaft next to the slipper clutch.
I have a feeling that something else is broken because there is quite a lot of noise from slipper clutch or somewhere in the back.
Check the videos and pics in this link: https://www.dropbox.com/sh/x59urmynp8zab49/AACxQbxd2ueKiOCMWs6hfSL7a?dl=0
Any suggestions on what to do?
Thanks in advance!
/Rickard
Thanks in advance!
