- Limitless
Long time RC hobbyist first time Arrma owner. Decided to build a Limitless for speed runs (something around 120 mph) and some bashing occasionally. This is the list of parts already bought, some have arrived, other are still in the mail or backordered.
Castle MMX8S 1717 1650kv combo (installed)
My old Futaba 4pls but just in case I have a brand new RC6GS V2
PPS motor mount (installed)
PPS diff mount (backordered)
PPS diff cover plate (waiting shipment)
DS 3225sg 35Kg steel coreless HV servo (installed)
Arrma front shock springs 35mm 32lbf/in (installed)
SFR carbon fiber side skirts (installed), front splitter (installed) front and rear air dams (waiting shipment)
RCAWD Rear Center Dogbone 103.5mm
Arrma Center Driveshaft High Speed Support Set (installed)
Alza Racing Motor 40mm Fan Mounting base, Motor Fan Base - Dual 40mm and Dual 40mm Aluminium Fan Cover (installed)
Two 40x40x28mm 12V Ultra High Speed Fans with an incredible stupid high airflow of 31.3 CFM each with a dedicated 3S 2200mah lipo (installed)
Avid Aura ball bearings kit (installed)
Arrma 29T and 39T Spool gears
Dozens of 5mm bore Mod 1 pinion gears from 17t to 36t.
GRP S5 tires.
Skyrc GSM-105 (new gen with 10Hz update frecuency)
Sunpadow 6s lipos 5100mah 60C and Sunpadow 4s lipos 7300mah 70C
Setup
Opened two holes to the upper front arms for easy access to the Droop screws.
Front toe 0 degree.
Rear toe stock
Caster increased by moving two clips to the front of the upper front arms. Front Camber 0 degree, had to add 2mm plastic washers to the upper pivot balls.
Rear Camber 0 degree.
Ride height 8mm front, 22mm rear.
Droop 0mm front and rear.
Shocks, 3000 cst silicone oil all around, stiffer springs on the front. Front shocks moved to the upper hole in the shock tower, preload around 60%, rear shocks at outer hole of tower giving more stiffness, preload all the way down.
Planning to change diff silicone oil to at least 100k front and 20k rear.
I haven't had the oportunity to do any speedrun due to a very high winds here in South Florida during the last weeks but I've had bashing a couple of times on 6s speeding to 80mph at times and the car runs very smooth.
Any recommendations for my build?
GRP S5 tires.
Setup
Front toe 0 degree.
Rear toe stock
