- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
Thanks, it felt like a good pass as soon as I ran it. I’ve hit 120 so I just want to keep going now! I’d like to get to 125-130mph now on this set up.
So couple questions -
-Yes I’m running 30T pinion and 34T spur. What do you think of going to 29T spur instead of gearing up the pinion?
- What about aerodynamics - front and rear wings are still stock - should I trim them right down?
-so is it normal I’m still only hitting 33k ish rpm?
I feel like I can get more out of this without changing much - they were good runs but I still squiggle a bit with keeping it straight. Are you guys running AVC receivers? Or does that take away from power...I’m currently not.
Yes, you wont see more than 33k on this motor as you gear up higher.
You could trim down the wing a little but overall you just need more gearing.
Some times the a gyro can do the wrong thing and fight you so most of us avoid it... Check the alignment and possibly look at removing slop from the wheels. Mostly this is shims on the axle stubs that go through the hubs and then Mugen rod ends and balls helps on the steering links and rear camber links.
Trim a little off the wings and gear up and see what happens. Taking the spur down 5 teeth or moving the pinion up 5 teeth does the same thing.
