You should probably post in the classifieds section on the forum...Hi
Looking for a set of 4 new katar tyres for the talion
AR550048
If used must be close to new
Thanks
Pretty sure typhon katars are smaller If I'm not mistaken?Are you located in the US? If so JRC has them in stock listed under the 6s Typhon (6s Typhon and 6s Talion use the same tires):
https://jennysrc.com/products/arrma...ar-b-6s-ara8606v5?_pos=1&_sid=57d317b1a&_ss=r
Just bashitrc also has them:
https://justbashitrc.com/shop/typhon-6s-dboots-katar-wheels-2-pcs/
Oh you're right my bad. I always thought they were the same and I thought they had the sams part # but just now noticed they are ARA550058 and not ARA550048.Pretty sure typhon katars are smaller If I'm not mistaken?
The only reason I know is because my buddy was using them (talion) on his Mojave and I had my typhon with the smaller onesOh you're right my bad. I always thought they were the same and I thought they had the sams part # but just now noticed they are ARA550058 and not ARA550048.
Ugh sorry dude.
