Defiant’s XMAXX Build
First order of business was to dye all my grey chassis components black
Started taking apart my old diff. This is the GPN spiral cut gear that stripped real easily
Inside.. DRY!
Cleaned up the spider gears and put them in a Hot Racing aluminum housing
Filled with fresh diff fluid
All assembled with fresh Jim’s bearings and drive cup sleeves
Nice and sticky
There’s something satisfying about a fresh diff rebuild assembled in a new bulkhead with stainless screws. I decided not to shim the front pinion as I believe it does not need it, I will add 1 to the rear because from everything I have seen, that one has loose tolerances.
Traxxas HD A arms and TBR skid plates
All new steering gearbox assembly
I’m going to reuse my 2085x servo for now, I’ll most likely go with a reefs triple 5 or a savox later down the line.
Tonight the center diff and rear diff are getting rebuilt
Dealing with this horrible greasy mess I hate this part
ready to go back together
Fresh fluid
Brand new pinion and ring I’m praying this one doesn’t blow up for a change
Stock center diff
ready to assemble
Filled it with silicone ear plugs
shied this pinion
I don’t know if I’ll stick with the white a arms
Are these parts a stock item or an aftermarket mod..?? and what do they do.??
Aftermarket. They are supposed to keep the drive cup intact. Or keep it from splitting. I’m running a 56113 and have never broke a stock drive cup. I have a set on my shelf and never found i needed them.
Nerf bars and battery hold downs put in
I grease my drive cups because these things squeak and drive me crazy, I’m sure it also helps with wear as well. I have Rovan axle boots to help keep the grease in and the drive cup sleeves keep the boots on without zip ties
rpm rear hubs of course getting the Jim’s bearings treatment
tbone racing wheelie bar with skateboard wheels mod
reusing the snap on rear bumper because it’s durable and idk where to get a new one
I never realised how much plastic was on a Xmaxx ?? plastmaXX
I'll take an almost all plastic basher to a chassis bending and heavier vehicle that breaks more easily any day. Trust me I know what I'm talking about. I have both kinds of vehicles (plastic chassis vs metal chassis) and the plastic chassis ones break way less while doing dumb stuff, skate parks and bad landings.
