Long post. Will be attempting to warrantee through hobbywing (sent prayers!). I'm looking for any insight as to what is going on.
Have a surpass 4274 1500 motor, 1 month old, not abused max6 esc on 6s. It most often happens initial turn on, but will also happen every 5 min or so during running. The esc will turn off and reinitialize. The telemetry on the radio registers low receiver voltage, which is different than if I turn off or unplug the esc. Will do this with multiple batteries, without the receiver, servo, fans or anything else connected to it. Is not water or cold related. Is an intermittent issues that will prevent startup all together or work for 20 min, is a dice roll. Power delivery, temps are all good when it works. Once every dozen or so failed start up, the esc goes dead - power button and unplugging lipo does nothing to bring it back to life. Capacitors need to be discharged then lights come back on an we are off again. If I disconnect 1 or motor wires, it starts reliably every time. Replacing that wire in usually works, sometimes will restart again. Multiple motors will cause the same issue, so it's esc related I believe.
Thought on failure mode? You can hear a relay clicking when it restarts.
