YesDid Arrma stop with the Senton 6s? The V3 from 2019 seems to be the last version?
Get a mojave and a senton body. Actually the senton is smaller, won't work.Did Arrma stop with the Senton 6s? The V3 from 2019 seems to be the last version?
Not even close to the same size. Mojave is as wide as a Senton 6S is longGet a mojave and a senton body.
Yep! I realized they weren't the same size like 10 seconds after I posted it.Not even close to the same size. Mojave is as wide as a Senton 6S is long
most real tanks (army or gas) aren't very fast. the only fast tank I know of is the arrma talion.Use mostly parts from the Typhon 6S. Get yourself the specific arms and shocks for the Senton 6S source a body and tires/wheels and you will have the Senton 6S. About two weeks ago though I seen a very clean senton 6S on ebay. I watched it but it sold pretty fast so some are out there but have to keep an eye out for them. I had one years ago. They are an absolute tank of a short course truck and I mean that in the best way possible. Heavy, tough and fast! I’ve got a Mojave now and it’s a nice replacement for it although it’s quite a bit largerView attachment 144142
That's the only one you have so you can't compare it to anything lol.most real tanks (army or gas) aren't very fast. the only fast tank I know of is the arrma talion.
says the person with only typhonsThat's the only one you have so you can't compare it to anything lol.
I want to get the talion eventually too though.
I have plenty of gas tanks (one in each 1:1 car+ some)That's the only one you have so you can't compare it to anything lol.
I have a redcat Volcano 16 and a traxxas slash brushed too. My brother drives the slash more than me though. If I get another car it will be the tekno 410.3 sc.says the person with only typhons
I used the typhon shocks and they worked fine. I don't know that you can find the senton ones. You might be able to find parts of them to build them but if you already have a typhon just throw the shorter arms on it. I think most of the length difference is outside of the shock mounting point. And for the turnbuckles just screw the typhon ones in til you get the angle you need. There are senton side guards out there but i put outcast on so they came up a little higher and covered more of the body from rocks/debris being kicked up from the tires.I’m looking at a Typhoon slider to build a Senton. If I’m right I will just need the arms shocks drive shafts turn buckles body mounts and bumpers? Anything else I’m missing?
BODY. But then again no body means less cost.I’m looking at a Typhoon slider to build a Senton. If I’m right I will just need the arms shocks drive shafts turn buckles body mounts and bumpers? Anything else I’m missing?
Is that even legal?ARRMA BRING BACK THE SENTON 6S.
Ever seen a senton 8s.....
Ran max6-tp4050 and mmx8s in senton on 8s
