MikeGruber
I have a Hobbywing max 6. Ran 3 packs so far and the first two I didn't beat on it too hard. The last one I bashed hard at a local skate park. My motor is a TP power 1520kv and it got in the 170ish range and my ESC also got in the 170 range lol. 175 to be exact. I was also running some trenchers. This most likely caused the extra heat also the fan on the ESC is garbage. I knew this from the start and have a wtf fan coming my way via snail mail but should it really get that hot??? HW specs are 160 amps but I've heard on this forum it can put out more then that easily. My motor is rated at 230amps max draw. I picked this ESC because of the mounting option in the stock location. The castle xlx or max 5 would need to be mounted above the diff. Not ideal but can be done if necessary.
