Barmaleus
- Points
- 303
- Tallinn, Estonia
- Kraton 6s
- Kraton 4s
- Thread starter
- #21
@parcou Thanks a lot for the pictures! It all makes sense. This is exactly what I did. I edited some of my previous comments, as they did not make sense
Apparently I was just tired and overthinking it
The only difference is that instead of 8x10 I used 8x12 shims. These were several dollars at AliExpress for 100 pieces
With those I can shim all RC cars within 200km radius, I guess.
I did remove one shim on each side on the rear to have a slight movement. So that it is 3x0.2mm shims per side on the rear axle.
The MAIN thing to avoid, as I understand, is a shim that is so big, that it touches both inner and outer bearing ring. Both 8x10 and 8x12 will work just fine.
