- Notorious
Hey, so I've seen another member as well as @bicketybam do this mod as well. Basically you replace some of you tray anchor screws from plastic to these
So they look like this? (actually I'm going to add a 4th one)
To do this you need M3 "t" or tee nuts, 4 each.
Counter sunk M3x10mm screws 7 ea.
C-clamp 6" or bigger
10mm or similar socket
Stiff cardboard or preferably 1mm plastic sheet (to cover bottom of tray)
4.5mm or larger drill bit
Dremel with grinding bit
The reason for the c-clamp & socket is to push them in on the two holes that pass thru to the mud guards, you'll be adding two more anchor points that attach the mud guards and battery tray.
On the bottom they will pass thru, you need the socket so the stem can pass thru when you clamp.
See the bottom mount under the velcro, that's where you'll drill a hole large enough for the shank to pass thru.
You'll need to dremel off the two middle screw mounts on the mud guard. The new t nut shank will replace these.
Final step is to cut a protective sheet to cover the bottom of the tray. These are metal, and you wanna take no chance they come in contact with your battery.
And you now have the strongest mount you've ever felt. ??
Definitely worth the $3 in materials & 1hr. fabrication time.
