Dielectric grease for electrical connections?
Casper391
  2. Kraton 8S
  3. Typhon 3s
Thinking about using Dielectrically grease on my electrical connections. Anyone use dielectric grease on electrical connection to help keep water out and help for better connection? Pros/ cons?
I haven’t yet but it’s probably a good idea if running in the wet or snow ????
I use it on my "1:1 Scale" car and antenna connections all the time. I don't (deliberately!) run my senton in wet weather, so I'm not too worried about it.
I can't see how it could hurt, though. It's pretty "inert" stuff, so it shouldn't affect the plastic bits. And it's not real sticky, so I wouldn't expect it to attract and hold a lot of dirt.
I use it on my 1:1 Wrangler & spouse's 1:1 Subaru. If it will withstand use in sparkplug caps on the cylinder heads I have no fears about it's performance on a 1:10 truck.
It goes on my 1:10 Granite's EC5 battery connectors and a tiny dab on every occupied slot on the receiver.
If nothing else I see it as "anti-seize" for the electronics.
Thanks for the info guys. I don't run in water per say like rain, but I do run sometimes in damp grass and mud, I do wash my trucks off ( with the body on) for a quick rinse then the wd 40 the truck down and use a air compressor to blow them dry, then a little 3 in one oil on all the exposed bearings.
