Diff brain isnt working
Chevyfreak06
I just got done installing the whole diff brain setup and it's not working. Everything is wired up right abd all the lights work but I'm not hearing and servos function. I got the kit off ebay and everything was taken from a brand new nero. I also tried setting end points but no servos are functioning.
hmmm..you try rebinding? ...what remote are you using ?...you did upgrade the remote also?..not sure if non diff remote has enough channels after diff brain upgrade. .
The non diff brain remote is the same as the diff brain remote. I have upgraded two non diff brain Neros and I also got the parts from ebay.
I would double check the wiring. The servo connections are easy enough but the one goes into the third channel and the other goes in line with the throttle if memory serves me correctly.
Since it lights up it sounds like your diff brain is plugged into the battery on your receiver. The AUX IN should be plugged into your 3rd channel.
Maybe it will be helpful.
At least you need a controller which support 3ch and on the 3rd channel a 4 position switch.
Also a 3ch receiver for sure.
  • NERO DIFF BRAIN CONFIGURATION 20160704.pdf
I got it all figured out had to program everything, but I think I got a bad micro servo. Rear servo worked great then went crazy buzzing and it wont adjust.
Im guessing since I got it off ebay im screwed prolly no warranty. It came out of a brand new nero.
mmhmm,
It is sure that the servo has miss function? Do you checked it with a servo tester?
Maybe a reset from the controller will help before you will adjust the diff-brain-board...
Buzzing servos means normally that the servo runs on block or can not run its complete way.
I miss also an servo saver on these servos like Traxxas it has.
Regards,
lonee
