- Felony
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Outcast 8s
- Typhon 6s
Was swapping fluid in the center diff of my Typhon. When disassembling my diff case insert came off the diff case. Is there a way to reattach this or is the plastic dif case melted into the metal insert at the factory?
Also I’ve been warned not to spray out the diff case with engine cleaner - is there a reason why? Does it not play well with plastic?
Finally - any suggestions for removing a stripped set screw from the input shaft cup sleeve? How on earth are you supposed to heat up this set screw to destroy the factory red loctite when it’s surrounded by plastic! So annoying. Was going to swap all the bearings for fast eddys but these are the last two I can’t get to so it might just stay as is…
Thanks
Thanks
