So I took a hot racing diff case, HR 50t center spool , Arrma diff rebuild kit. All brand new. Built it as specified and attempted a dry run. Thank god I did. Anytime I tightened the screws down it locked the diff. Like the diff case is too short if that makes sense. I took a reg carrier whatever you choose to call it . Reg as in Arrma plastic. Butter. So only difference is the case. What gives. And I also tried it with shims, without shims, and same results locked up. I was wondering what was everyone else’s experience with these diff cases. I bought a red aluminum Arrma diff case in the past and it goes together a little different but no problems there.
