That fluid combination is illegal in some countries.I want to try 60k earplugs 60k set up in my diffs
Would that be a good setupWhat's the question?
What truck?
Where are you located?
Whats in the centerSo you want to lock your diffs then? Might cause some issues. I run 10K rear, and 30K front and its been perfect. Any reason you want to basically lock them?
Ok. Now I understand what happened. You have this posted in the 4x4 forum. Im assuming you are referring to a 6s. That's why I thought you were talking about using ear plugs in the diffs. The 4x4s don't have centers. They use a slipper spur. Might get better answers in the 6s forum.No I wasn't trying to lock all three. just the center I thought 60k would give the front and back play and more power
Florida
Kraton6s
Whats in the center
The "ear plug" affect is closer to 1 million. 60 k is still very light, and normally only used in the front or rear dif. You can buy 100k, 200k, 500k and 1M in fluid form. If going the ear plug route, it has to be the clear silicone kind, not the neoprene colored ones. If you are new to the hobby, I would start with 100 or 200k, and work your way up from there. Locking the center in the way you are describing can put a lot of strain on a basher. It's typically done on speed run vehicles, instead of using an actual spool (locking system).Thanks alot
For bashing on grass, highly recommended but this is a personal preference, not a 'best setup'. It is the best for myself.How does it run 60k F, 500k center, 30k rear
