ilias_cupra
Any suggestion i reached today 109 miles with my limitless. But i have stock diff fluids and i think i must change them!!!
Whats you recommendation??? I ve already put in front 200k, what shall i put back?Thick diff fluid or locked diffs will help in straight line speed by keeping power equal between wheels, which forces it forward in a straight line. When one wheel diffs out, you spin out or blow a tire. So yes you will be able to hit a higher PB. The more stable your rig is, the faster you can go.
That’s probably ok to start with. Give it a try and see how it feels for you. I went 500k last change.Whats you recommendation??? I ve already put in front 200k, what shall i put back?
So i put and rear 200k? Like the front diff?That’s probably ok to start with. Give it a try and see how it feels for you. I went 500k last change.
For a speed run car yes. If you need to turn, you would want thinner in rear.So i put and rear 200k? Like the front diff?
I don't turn, only speed runs! So i will see it with 200k front /rear!For a speed run car yes. If you need to turn, you would want thinner in rear.
Yes you can go as thick as you want. You can even use putty and lock it. That will probably be my plan soon.I don't turn, only speed runs! So i will see it with 200k front /rear!
After that i will try thicker fluid!
500k front /rear will be ok???
I have spools and 500K fluid front and back in all my speedrun cars, its thick and makes a big difference from stock. I can get the power down nicely with it. Next time I might try 1 million weight. 20 million seems like something big 1/5 25 pound trucks would use, pretty extremeHow about we 20mill front and rear? I want the car to be more stable going straight only. Right now I am on 10k front and rear but the car is little hard to control when taking off would 20 mill fix the issue or should I do 500k front and rear?
How was that?I put 1million in the frount and rear!!
Why must you change them?Any suggestion i reached today 109 miles with my limitless. But i have stock diff fluids and i think i must change them!!!
Better, now I run diff lockersHow was that?
How was that?
I love the answer and I will add one thing, which is you can turn with 100% locked diffs. But you need to be careful with tight turns.Thick diff fluid or locked diffs will help in straight line speed by keeping power equal between wheels, which forces it forward in a straight line. When one wheel diffs out, you spin out or blow a tire. So yes you will be able to hit a higher PB. The more stable your rig is, the faster you can go.
