I've been wondering the same?Has anyone tried white lithium grease?
You put grease on the pinion and ring gear (outside of the diff) and silicon oil on the inside.I am confused here (noob) red and tacky is a universal grease isn’t? Do you put that inside the diff instead of all the fancy stuff silicone based oil?
Thanks buddy. I’m in the clear now!You put grease on the pinion and ring gear (outside of the diff) and silicon oil on the inside.
And you need some sticky grease so it lasts longer and won’t sling off the gears at high rotation speeds. Hence the red and tacky.
