SOLD / FOUND Diff input and ring gears
Status
Not open for further replies.
Ohio
Hi guys I really need a new diff pinon input gear and ring gear. I think I will need 1of the not Safe-D gears. Also would like it if I could get a diff housing The input gears I need are 10 tooth spiral gears. Hoping to find some CHEAP because I need new input gears and ring gears to bring the Kraton 6s to Montana and Colorado on vacation. Thanks to anyone who can help me out!
Um Thanks??
I just posted something on this forum just wondering if anyone had any that they would be willing to sell for cheap. I know that this would probably be highly unlikely.
Gears are changed in sets...or you better stock up on alot of input gears cause it will smoke one every couple runs if you put them against a used ring gear..
Good luck..👍
Trust me I do chores around the house like cleaning our chickens coop and mow the 3 acre lawn but I've been putting nearly all the money I earn into my Kraton. Seems like the drivetrain problems don't end.
Right but I'm just replacing what needs to be replaced not anything extra. I was wondering what you meant by slowing it. I don't really know how.
Make certain that you are shimming your diffs properly & not on the throttle when landing jumps would be my best advice to "slowing the money pit" on your diffs. And like Camaroboy383 already mentioned, replace gears as a set.
Yeah I'm learning as my kraton 6s is my first true hobby grade RC truck. I'm not new to rc or new to how mechanical things work either. I shimmed the crap out of my front diff I'm positive that's the one that needs to be replaced. 3 shims on the gear side seems to not sound like it's skipping to often so I should be able to get through vacation. I always try not to be on the throttle when I land from jumps and mostly just brake in the air. I did a lot of research and that is a big mistake.
Status
