- Mississauga
- 4x4-Mega
- BigRock 4x4
- Granite
- Typhon 3s
Ok. Sorry for off brand.
I have a kyosho fazer mk2.
It's very much like an arrma 4x4: rear motor which is mounted same alignment, Awd centre shaft deal.
I put a sidewinder 4 5700kV motor ESC combo in this thing and it is stupid.
It basically roasted the stock tires in one 2S pack.
The big issue is: throttle = donuts.
I have 5000cst oil in the rear diff and used lithium grease in the front.
As near as I can figure I need to stiffen up the rear diff. I figure the power plant is too stupid and once the rear diff starts to slip it just spins this fiddlesticker around like mad.
I mean beybladeshit.
I got some new shoes coming.
Bought some 30mm wide for the rear.
Harder tire compound. 45 shore. Hopefully they'll last a bit longer.
But for advice on the diff(?)
I am going to try and swap the front and rear and see what happens. Or just get a thicker oil for the rear. Will this help(?)
