Thanks help me very muchJust changed my diffs to 30k/300k/30k Front/Center/Rear and HUGE difference in dirt handling and grass acceleration. Really puts the power down in high traction scenarios and in the dirt, it corners SO much better. I have a little course that I run here at home that consists of my grass yard and my dirt driveway, and it's so much better. When I go to turn on the dirt corner I just flick the servo to the right and punch the throttle and the tail end of the truck kicks out perfectly and just floats sideways around the corner. Almost like it's my drift car with a gyro in it. I was floored when I did that move. I've had the Mojave around that course dozens of times and with the different diff fluids I couldn't believe the improvement.
Not only that--in the grass--the truck traction rolls far less. For example, if I'm coming into a corner and let off the throttle, the leading tire in the rear doesn't stop, grab the grass, and roll the truck... It more-so matches the speed of the following tire and keeps rolling and the truck just either pushes or loses traction and slides out. It's PERFECT for my needs. Speaking of the grass, when I punch the throttle, because of the 300k in the center diff, the front tires don't grab all of the power and balloon out... The power is more evenly distributed and the truck just absolutely tears up the grass and goes forward with a vengeance. Big improvement to high traction acceleration. No wheelies though (because I turned my punch to level 1).
I also changed my shock weights to 70 in the front and 55 in the rear. No report here yet. I took a few jumps on the septic mound and I... really don't see much difference...? We'll see how that turns out.
I think 500k for the center would be fine in such a long wheelbase rig.Hi I am going to run on mainly grass so 30k/300k/30k as mentioned above sounds good but what if I put 30/500/30?hmm I can only find associated 200k and not 300k?
I put in 60/200/20 and handle great I having lot fun with that combination I used dirt and grassHi I am going to run on mainly grass so 30k/300k/30k as mentioned above sounds good but what if I put 30/500/30?hmm I can only find associated 200k and not 300k?
The reason I opted for 300k over 500k was because these center diffs have been known to melt down from extreme use and thicker fluid will certainly not help that issue. So far, my 30/300/30 has been working out really well. Less traction rolls and more power to the ground.I put in 60/200/20 and handle great I having lot fun with that combination I used dirt and grass
You have it backwards IMO. Thinner oil makes them work more and heat up. Thicker locks the diff more and keeps them cooler.The reason I opted for 300k over 500k was because these center diffs have been known to melt down from extreme use and thicker fluid will certainly not help that issue. So far, my 30/300/30 has been working out really well. Less traction rolls and more power to the ground.
How would 100k-500k-80k work?I run 50k/200k/20k in front/centre/rear - I’m happy with it, running my Mojave mostly in grass and dirt.
I’ve tried a bunch of diff weights. I prefer 125/500/75. I run 6s and go hard af w this rig and it seems to be perfect for me.have 6S BLX not the EBX will the 50k/200k/20k for diff be good as well. Thinking of going shocks F 70and R 55
