- San Diego, CA
- Fireteam
- Mojave EXB
- Outcast 4s
- Talion EXB
- Typhon 6s
- Typhon TLR
- Vorteks
- Infraction 4x4
Curious to know—I've read enough to understand the differences between thicker vs. thinner weight f/c/r diff fluid (changing the oil's viscosity if you want to be technical ). That being said, I'm curious if the weight of the diff oil should be increased if the overall weight of the vehicle is increased. For example, if I owned a 9-pound Typhon with no aluminum upgrades vs. a 12-pound Typhon with every M2C aluminum upgrade there is, would that extra 3 lbs require me to run heavier diff weights?
My Typhon TLR weighs 11.2 lbs w/ out tires mounted. I don't remember what it weighed before, but I had to increase the shock spring rate. I'm using the Mojave 70mm front springs (7.0 lbs/in) and the Talion rear springs (5.4 lbs/in). By comparison, the stock front springs are 4.74 lbs/in, and the rear springs are 3.17 lbs/in. So, I definitely put some heavy-duty springs on it to handle the extra weight of all the upgrades.
Based on the heavier weight of the vehicle, should I also consider heavier weight diff fluids? I'd love for some folks to "weigh in" on the topic.
