BillyBones
- Senton 6s
Okay thank you guys all your input I’m put 100.000 center 10.000 front back I’m new to all this thanks
?As he states, it is a good idea as it helps the front wheels from ballooning to much on you when trying to hit the higher speeds. A little thicker oil in the center diff will also help limit front wheel ballooning. Helps a ton with your handling, as more tire is touching the ground to help you turn better or get back up to speed!Personally I'd put thicker in the front like 50 or 60
?As he states .?As he states, it is a good idea as it helps the front wheels from ballooning to much on you when trying to hit the higher speeds. A little thicker oil in the center diff will also help limit front wheel ballooning. Helps a ton with your handling, as more tire is touching the ground to help you turn better or get back up to speed!
Have a good one!
