bAdNeWs-89
- Limitless
Right I'm upgrading the Diff on my limitless any recommendations on oils. The car is going to be doing mainly high speeds.
If you don’t need to turn, basically drag racing or speed runs, the higher the better. You can go as high as you want, even full lock.Right I'm upgrading the Diff on my limitless any recommendations on oils. The car is going to be doing mainly high speeds.
I don’t think it matters on brand. I would buy 100k 500k and 1M to start. I would make some test hits with the stock diffs just to get a feel for the stock open diffs (10k).There will be minimal turning as I'm basically building a drag. Any recommends brands and strength's.
Sounds like a great plan. I think if it were me, I would be buying four or five spare diffs from Jennys and load them up with various weights (mark the weight on the main gear) and have them ready to pop in. That way in back to back hits you can see the effect right there. Then run with the best one. ????So if i try 100k rear and 500k for the front as my first spare diff set up and keep stock for now i can play about. ??I don't think i will lock diffs As it is always good to have some turning
Great thank you for your helpSounds like a great plan. I think if it were me, I would be buying four or five spare diffs from Jennys and load them up with various weights (mark the weight on the main gear) and have them ready to pop in. That way in back to back hits you can see the effect right there. Then run with the best one. ????
Keep us updated with your findings. Vids would be great! ??Great thank you for your help
Yeh will do it wont be for a bit as I've got a lot of work todo on it. But as soon as im up and running ????Keep us updated with your findings. Vids would be great! ??
Let us know if you have a YT channel so we can sub. I’m considering the same path so your results would be gold for me ????Yeh will do it wont be for a bit as I've got a lot of work todo on it. But as soon as im up and running ????
