slpcrf450x
Just thought I would give everyone a heads up that not all of the diff shims are the same thicknesses.
TD310475 sun gear shim - .007"
TD310476/Arrma satellite gear shims - .006"
Mugen E0206 sun and satellite gear shims - .010"
I know a lot of you use a total of 6 satellite shims, 2 on one side and one on the other of each shaft. I personally am not a fan of using different amounts of shims on either side but we won't get into that. If you do 3 of the TD shims you have shimmed a total of .018" 3 of the Mugen shims gets you .030"
The best solution in my mind is to use 2 of the Mugen shims, one on each side for a total of .020" per shaft.
Sorry for the backwards pictures my front facing camera is the only one that works on my phone right now.
