Cheers bra !! Got some on the way@Camo
Hey man,
If you are looking for external diff shims, I used the Tekno ones TKR1222.
See above post, I took a pic of the packaging.
Hey man,
The E0206 Mugen shims (small satellite shims), are slightly thicker than the stock and/or Durango shims. As such, using them in addition to the existing shims is not a good idea. The usual method for satellite shimming using the TD shims is to go 2:1, 2:1 on the cross pins (so 6 satellite shims total per diff). If using the the Mugen's, than there is no need for that...simply replace the existing shims with 4 of the Mugen shims. The net result is a total shim distance value that is equal to or slightly greater than - using the 2:1 method noted above. The added bonus is the satellites are equidistant in terms of spacing as relative to each other, and the planetary gear. This in conjunction with a larger shim under each planetary is a tight, perfectly shimmed diff. Add one or two external bearing shims to remove any residual slop with outdrive shafts/cups.
As others noted above, a slight notch is good...because diffs always 'settle' after a few packs and said notchiness usually lessens as a result.
How has that worked out for you? What have you done since. Got a kraton and going to shim but still not sure on some things.I followed the youtube and for the front used the 6 sat shims with mugen leaving the stock shims, the car did drive fine or so it seems
I did the rear as well but was only able to put 5 in as that was all that is left
Turning the diff was pretty difficult manually but in the car it drives
How exactly should the diffs FEEL, as im not super experienced
I plan on going back in and removing the stock shims and just using 4 mugen shims per diff, BUT that means i need 2 shim packs since there are 11 total and i would need 12 if i do 4 in each
How do i know if i need bearing shims or not?
I’ve found (in my cases) that the perfect recipe is 4 Mugen shims and then the 1 per set trick except I use the arrma factory washers here. So 4x mugen and 2x arrma washers on the satellite gears.Damn just read this and just shimmed my diff with that 2-1 with the spider step using the mugen shims. :/
