Based on prior threads, my understanding is that with Castle ESC's, Torque Control limits the actual torque a motor is able to deliver. With torque being defined as, the amount of rotational force the motor can deliver. From what I understand, Punch Control imposes a limitation on how fast the motor actually responds to an increase in the input throttle signal from the receiver.
First, is what I said above correct? And if so, my real question is, under what scenarios would one choose to limit torque versus limiting punch?
The main reason I am interested in toying with these is that on my Kraton EXB, after 10 packs or all three of my diff output drive cups "behind" the center diff, including the center diff output cup that faces rear plus the two out-drive cups on the rear diff, started to get chewed up by the dogbones.
I was running 500k center diff fluid which probably has something to do with it. With thicker fluid more engine force gets applied to the wheels that get traction under acceleration, which are the rear wheels. I was also using the 25% punch control setting and no torque control.
Since then I've replaced the 500k center diff fluid with 200k fluid, replaced the EXB output drive cups with M2C output drive cups (which really look exactly the same in terms of dimensions and thickness of the material), and bumped up punch control to 30%. I'm now wondering if I should introduce a bit of torque control as well....
