Difference between circlip pliers
kaladeth
Rig of the Month Winner
Mountain View, CA
  1. BigRock 4x4
  2. Limitless
What is the difference between these two?
Knipex 90 Degree Angled Tip External Circlip Pliers 10-25 mm dia - Plastic Grip
46 21 A11
https://www.kctool.com/knipex-90-de...nal-circlip-pliers-10-25-mm-dia-plastic-grip/
Knipex Precision 90 Degree Angled Tip External Circlip Pliers for 10-25 mm shafts
49 21 A11
https://www.kctool.com/knipex-preci...-external-circlip-pliers-for-10-25-mm-shafts/
Internal vs external refers to if you were squeezing them open vs squeezing them closed to release them.. if that makes since to you. One opens, one closes the clip to release.
One on the outside of the work piece.
One on the inside of the work piece.
Those look like they'd do the same exact thing. 🤔
Either one would probably work fine. I went with the precision one; it has a spring also.
Found a video that spells the difference, and also how to pronounce Kuh-nee-pecs.:
