blackgoat04
- Granite
so I have this idea. It might be stupid, but I will ask anyways. I'm not sure if any companies currently make something like this but I haven't seen anything. I'm about to change the differential fluid again in both of mine just to play with the mixture a little bit more and try to get it to drive how I want. I was wondering if it would be a stupid idea to drill and tap a tiny hole on both sides of the diffs. my thought is that pushing fluid into one side will squeeze all of the old fluid out of the other side. that's making fluid changes relatively easier. kind of the same idea as a grease fitting on a truck or something. and of course have tiny bleeder screws that I could put back in the holes to keep them from leaking the fluid out.?
