- Outcast 6s
I just tore my truck apart and was about to put the diffs back together when I noticed some of the teeth on the differential gear are worn/ broken. Is gear still okay to use or do I need to wait and get a new one?
It was the pin that holds the the differential gear on the diff.
What pins would you recommend?ya figured.. that pin breakage is common.. shimming them helps alot.. or better pins
that also could have been alot of the clicking.. ?
Thanks for the solid advice much appreciated!well you can use titanium rod and cut your own, use a quality drill bit and again cut your own...or you can use tekno pins and output cups.. you can also use tekno gear sets for the internals.. supposedly the gears that split from that pin breakage are better.. 90% of the time the pin snaps and pops the gear into pieces as its forced through the bore..
let me see if i can find the parts to show you..
i was mistaken.. its mugen parts.. not tekno...
