Dirt-Nap409
Hey guys n gals, I know this has probably been touched on but I have to ask. What is the stock tooth count for the idler and the differential gear? Do they make an upgrade for these to further play with gearing ratio's? I have 12 through 18 tooth pinion gears I'm going to try with the 0.8 MOD. Not sure if I should go back with the original 48p spur gear for better ratios or something I'm looking for in the unit. I want torque and speed and I know I can achieve it, I just have to find the right balance from the motor all the way through the drive train. I can mess with voltage and battery power later, for now I'm concentrating on gears. I am going to try and stick with 2S on this Granite but may move to 3S later. I have the hobbywing max 10 3660 4000kv setup which states can run 2S through 4S in the ESC.
